I don't think for you that going out of the range of pump gas will do anything for you.Itsa streeter going for the look.Would it matter to you if you had 650HP or 800? No Your not going to the track and will never have traction.Mild pump gas build will require less maintenance.Build it right and get YEARS of fun
HEMI-ITIS has no cure. My condition is fully BLOWN!!
