One note specifically about plastics. Some plastics are hard and others are soft. They all have have a vapor pressure that slowly breaks the chemical bonding. Everything is subject to it. Put that plastic in an environment that is subject to heat cycles and numerous petro chemicals and you will destroy it faster. Call Barry Grant. They are now making a TQ carb-3 BBL. See what they recommend for their phenolic bowl repair.
