You might just want to take a drive up to Best Machine in the Detroit area and talk to those guys. They can answer your questions and get you set up with a block. I wouldn't even consider buying an aluminum block direct from Indy. Let someone like Best run interference for you. They deal with Indy all the time and know who to talk to and what to order. They also know how to fix the block so it will actually work.
