Originally Posted By 68dodge
Are traction bars any good if you have them right up to the front leaf spring eye? Trying to get mine to hook better.
Do the front end work first. Do everything you can to make the front end to move as freely as possible.
I tried to video it, sorry for the quality.. but you should get the point, what clutch tried to say..
No shock is going to fix the movement when the arms does not move.
