What can be damaged by racing with a forward pattern manual valve body?
I see of the Turbo Action manual valve bodies can be used in forward for racing.
Cope has a manual shift forward pattern valve body that says forward pattern is NOT for racing.
Turbo Action says you can, and Cope says you can't.
Just looking for some input.
I’d say buy the T/A one then.....
cope isn’t saying you CANT race with a forward pattern transmission, they’re most likely just saying that particular product they make is not necessarily aimed at a race-only application.
