R3DART,
i'm in the process of building a stock stroke 360 with W2 heads. my heads were ported by Jesse Robinson known as RAMM on this site.. they flow 286 cfm.
i'm going to run a solid flat tappet cam. Hughes Engines grind #, STL6468AS. 615/621 lift with 264/268 dur @ .050.
i will use a Victor 340 single plane intake. compression will be at 13.1.
i have used a holley pro dominator tunnel ram in 2 different builds. 360'' and a 440'' SBM stroker. i ran 2 650 holleys.
