I did my mirror several years ago and what I did was just to submerge it in a bowl of lacquer thinner - after about 24 hours the mirror just fell away from the adhesive. My mirror was chrome. If you have a painted mirror then your options are limited. My mirror was loose so after I tightened up the pivot I used some construction adhesive to bond the mirror back in place.
