Well, I pressed the sleeves into the retainer and then the bolts would not go thru. So, I removed the sleeves, destroying them, and installed the retainer the old way, with no sleeves. Seems to be O.K.
It looks like the blue side seals are compressing more on one side then the other, but looks to be sealing O.K.
I miss the old reliable white seals. They would expand and seal great and seem to be more forgiving.
Jeff
