Yeah the 1.32 housing, T6, 96mm turbine is the common s480. That little 340 will need a bit of work to get that turbo lit. When my 367" had the wrong (tight) converter in it, it would take over 10 seconds to spool from an idle. But once it gets to 5psi, it'll go to 20psi in less then 1 second.
