yes thank you i read it but it wasnt that clear to me, im just trying to ask it in a more understandable way, maybe its just not clear to me, trying to find out hoe the rod lever connects to the door mech. its impossible to pu on the c clip to the back of the lock barrel when its already in the door, so i though maybe i can take the rod out of the door mech, build the whole assembly outside of the door, slip it back in thru the lock hole then hook the rod back up to the door mech, i just cant figure out how the rod attaches to the door mech inside the door..
