For the smaller upper hinge that came with factory bushings, simply tap out the old bushings and tap in new bushings with a new pin.
The larger lower hinges that had no factory bushings should only be rebuilt by drilling and reaming and installing an oversized pin, not by installing bushings where there weren't any. Here's a link to a good kit. Don't buy kits that include bushings for lower hinges.
If you don't see two dolphins, you need a vacation.
