On my 01 Ram 1500 4x4 the rotor would not come off the hub bearing.. at all, tried all types of lube and heat, no go..
Rented an enormous puller from the local rental place, and that got enough leverage to break the the outer brake pad surface away from the offset center of the rotor. Now it was a two piece rotor.
A few more hits with a really BIG hammer and I finally got the remainder of the center of the rotor off.
I now own a larger tub of anti-seize.
The hub bearing removal method in the video is what I also used... they are not coming out either...
