Used them for years with no issue's other then yours they leak at the bellows part of the shock.Like you said its nice o be able to lift or lower as need be but once spring s are in place you cannot easily do itGet used to buying the air shocks I have found Gabriels and Monroe lasted the longest if they still make them?
