I dont have a pump in front of me but what I would do is stick some bolts into it on your bench with some lock washers & you want (iirc) 1&1/4 times or a slight bit more than the bolt shank dia, that length of threads to engage into the block. add in the timing cover thickness & its (2) gaskets
