So what you are telling me is the gasket does not cover the whole flange on the cylinder head and there is exposed sealing area area?
Yep.
Can you set the gasket on the head, throw in some bolts for alignment and snap a pic or two of the flange area?
Yep.
Thank you! look forward to the pics
Pics taken, but I need to resize them before I can post them. Should be later today. FWIW, the sealing area is reduced to .200" on the top rail due to the differences in gasket railing spacing.
