How come indy don't supply a gasket for this?
Got the Indy valley plate which has to go on before the heads (572-13s) , got an oil leak between heads & plate even though the heads were bolted down on a bed of sealer , seems the gap between heads & plate is a good 3/8".
Anyone else have this problem , as said above , WHY don't indy supply a gasket?
