Can I put older style straight axles in my housing with the vacuum pod setup for engaging the 4 wheel drive? If so would I have to remove the vacuum setup and make a block off plate? I believe the axle I am referring to is 1985 and up and want to use my 83 axles. Thanks. Greg
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
