I recently bought a '68 and earlier "timing pointer" so I could use a '70 and up timing chain cover and still set the timing from the passenger's side.
why did you use the later tcover? were you using an early wp w dr side hose & wanted to time it without having to deal with that interference & also did you use an early harmonic dampener or remark a 70 & up one?
