more progress , the adjustable frame mounts i ordered didn't work out the way I wanted so I had to go a different route .shot of the shock cross member cut out and new cross member for the upper link mounts .
got more done today , the hoops legs go thru both sides of the frame and are plated on the inside of the frame .tomorrow ill see if I can make the upper coilover mounts off the hoops
