The 3-speed switch uses the 2-speed connector plus a single wire connector. The extra connector is already on the harness but taped up if only using a 2-speed switch/motor. Find the appropriate color coded wire in the schematic in the FSM and you'll find it on the harness. And its also already in the bulkhead connector.
