First choice should be rebuilding. Unless worn, the factory parts are almost always better than the replacement parts. Yes, aftermarket 20:1 and 16:1 worm gears have been made and their quality has varied. Anyway, the question wasn't about changing ratios, it was about rebuild. It may just need repacking with fresh grease and new gaskets, readjust and good to go.
