That's it, thanks!
Does that play well with the steering brace I just ordered? I'm trying to picture everything together but sitting at my computer without all the pieces It kind of looks like it's one or the other to me, but what do I know? I'll answer that; not much! Thank you.
Here is a install article for that strengthening kit. http://ramchargercentral.com/articles/?sa=view;article=176
It looks like the brace would still go on the back as the bolt pattern will be the same, but you will need to put a new hole in the front crossmember and possibly do some bending/tweaking. I personally wouldn't do both, the factory solution should be good enough.
