1) Can I run the stock 13 Ram power steering pump with my stock 69 steering box or am I going to have to go to something else due to size and pressure considerations? If so, what, the Borgeson box?
I believe you need to reduce pressure of the stock pump. Bouchillon sells reduced pressure p/s pumps or you could plumb a an adjustable p/s valve.
Maybe there is a way to reduce pressure of a stock pump?
Also see that people swap for a Saginaw 2 pump.
