IMHO the single reason why people give up on it for street use: the tuning is very similar to anything else with a primary metering rod and vacuum secondary (AFB, AVS, QJ etc.) except that the secondary air valve is also linked to the choke mechanism. Just follow the manual and you'll be fine.
