I don't have a firm answer for you, but I think you can put the codes together similar to a build sheet. I assume that there are some threads here on Moparts or somewhere out there that covers decoding the IBM cards, but I'm coming up blank. Maybe if you can scan the card and post an image, someone will chime in on what to look for or how to pull the codes out.
