Ok, So now we have a disagreement, and some high end cars would have wrong air cleaner on them.
I do know the tube does not pivot unless the assembly became broke/loose. I also know that folks have modified the base to change the orientation when as an example a 69 383 Air Grabber base is used on a 70 Air grabber (for the larger oval air cleaner).
So for the hemi it does seem that we only have one base being sold as a reproduction, but that would not be the first time the industry decided to standardize a reproduction part to avoid multiple variations.
So back to the superbee... Does anyone have original pictures of 69 hemi airgrabber or ramcharger with the driver side breather?
