Originally Posted By DAYCLONA
Originally Posted By bigblockbryan
Kinda I really want a charger I just can't see spending 10 grand on a shell and still having rust to fix I was planning on ordering all the metal from amd but then this coroner came up I started thinking it maybe just as easy to do this instead I was just curious to see if anyone else had done this or thought about doing it
Rather than cutting up both cars to make one Frankenstein quilt and patch work creation, just de-skin the CORONET enough to hang any good used sheetmetal along with some AMD full qtrs and whatever associated body panels you need to convert the CORONET into a Charger, then swap the Charger VIN onto the new shell
That's just a little bit illegal. Swapping VIN tags can get you serious jail time.
Maybe if you were dealing in stolen cars, which the laws were intended for, not for some enthusiast restoring or creating a vehicle from a number of donors/parts that are legally owned
The law doesn't care. You can have all the good intentions in the world but VIN swapping is illegal no matter how (or why) you do it.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
