Your carb must be 2" above the hood line on the front edge.For jetting I ran 88pri/92 sec no pv's so I will be interested to see what you end up with a pv in front if yoou do that.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
