As I said previously....... For a basic bracket build...... It would be something fairly unglamorous. Low 270's@.050, barely over .600 lift with the 1.6's....... And IMO it would still need to be broken in with the inners removed, and the spring pressures and heights would need to be verified.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
