I've seen close to 10° temp drops using one of the pumps like a Flow Kooler w/ the plate on the impeller compared to a stock style pump. I've also used the Milodon version w/ success.
Keep in mind that these style of pumps require the use of a balance flow style thermostat like a Robert Shaw. They claim the added pressure from the pump will close a standard style thermostat.
