We have done it for years. Doing a Hemi right now dated Oct 11, 1963! We always bore one cylinder on one bank and then one on the other. Then we install the sleeves. Then do two more on opposite banks. Some shops just bore out all 4 or 8 and then bang them all in which really pushes the block around. We also never do 2 cylinders side by side. If you start with a center cylinder you can then move to the far end cylinder then go to the opposite end cylinder and then the other center and never do two side by side. Same with honing. Also, we always use dry ice or liquid nitrogen to drop the sleeves in without banging on them. You always need to align hone afterwards. -- Ray
Good to know
