A&A Transmissions has a good selection of governors that can help with your shift points. But, they usually introduce split shifts that can be a whole 'nother issue to deal with.
If you have a cone that will hold both tires after all these years, then you are doing better than most of us.
I'll bet that you are blowing one tire off on the hit given that big a difference in tire temps.
