What wheels do you have, or more to my point, did the offset change with change of wheel from OEM? Reason being, I've always suspected a change of wheel offset, would change tire "scrub, and might lead to wandering, this point I mention it because it is seldom discussed, why (?), because it has no merit, or whatever? Just throwing it out there.
"When the vehicle has been modified with offset wheels, larger tires, height adjustments and side to side camber differences, the scrub radius will be changed and the handling and stability of the vehicle will be affected." Wiki
https://en.wikipedia.org/wiki/Scrub_radius
