I assume you have a ND (2005-2011) Dakota. It shares bolt pattern with HB (2004-2009) Durango and Rams from at least 2002. They all use the same hub I believe.
The offset is slightly different between the Durango and Dakota, the Durango has about 12 MM more positive offset. The wheels should work, but double check your tire clearance.
