The Hughes 1016 has the same duration at 50 as the stock HP cam, but lift is 0.480 rather than 0.455 or whatever, and LSA is slightly tighter at 212 rather than 115 or so. Those two changes make it a better cam,
Both Crane and Comp have versions of the stock HP cam which have been tweaked by their lobe designers to have smoother valve action. If you are a Crower fan the 267HDP is a very nice 383 cam.
It's hard to recommend a MP cam because they appear to be trying to keep FCA out of bankruptcy by asking unbelievable money for cams.
Summit cams? The small one is too small and the large one is too big, with more than 230 degrees at 50 on the intake lobe.
R.
