The complete assembled head with 2.02/1.625 valve is set up to take a .525 lift cam. I was wrong about .550 lift (I was guessing based on what I remembered). However, Indy said if you want to run .550 lift, they can set it up that way.
I am running the stock cam (.430ish) so I wasn't concerned.
