Who makes the best shaker hood conversion for best quality?
I mean a hood that needs sanded and painted?
Also, who supplies the best detailed shaker scoop, doors, adapter/base plate and all the miscellaneous hardware in the repro line?
TIA
You have a choice, piece it together using the best from various vendors, or pay thru the nose and have it done the way you want it from the likes of SixPack Performance in Albuquerque NM, otherwise the number of vendors supplying a "drop in/bolt on, paint ready" set up are few and far between
