Originally Posted By Thumperdart
Run it, then make bowl vent tubes connecting the two with holes drilled in the tubes connected w/spark plug boots..........Confusing....... laugh2
Not at all. I've seen that done before. Was going to just bend up a brass tube across the original vent tubes and put holes across the top side. Cleaner looking than the plug boot trick.
[image][/image]
