Originally Posted By 383man
They usually sell a gear instalation kit which should come with all you need like pinion and carrier bearings and the oil seal and so on. Ron
The install kit is definitely the way to go. You'll just need to know if you have the large carrier bearings or the small ones.
Lots of videos on-line on how to do the swap. Best to have an experienced tech do the job, but you can pull it off if you just take your time.
Master, again and still
