another method that works is using a "crowfoot" wrench that fits the tube snugly and won't go past the flare "stop" at the bottom of the tube. then, using an extension of the appropriate length, tap on the extension until the flare is seated. you still must be sure the tube size is correct, which may need sanding/polishing to fit the hole in the block.
beer
