The trans is from a 87-91, plug is oval with 2-wires plugs into the case by the shift levers, it it next to the neutral safety switch plug, which is round with 3 wires I believe. I can email or text a pic to you if thats ok, I will gladly pay you for it. Thanks!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
