Re: Plastic repair Q...
[Re: Darius]
#232526
02/22/09 05:38 PM
02/22/09 05:38 PM
If you KNOW the piece you want to repair is truly ABS, you can simply go to Home Depot, Lowes, etc. and buy some ABS glue in the plumbing dept. It is the BLACK (as opposed to purple or clear type)type used to fuse ABS drain and waste plumbing pipe at the joints by plumbers. It WILL fuse ABS back together.
Have you tried this method?
Is it sandable? paintable?
My repair will definitely be "seen." Whatever method used will have to be able to clean up as if it was never there, ya kno?
