I use simple oils with one container of comp cams zinc additive.
All posted will work, try to find the cam and lifers maybe off ebay that from the late 70-s to early 80-s, although ive never wiped a cam I do feel the base materials have also gotten cheaper.
Std older comp 821-16 non edm lifters are hard to hurt...
http://www.ebay.com/itm/COMP-Cams-Solid-Lifters-Flat-Tappet-Chrysler-340-360-383-400-Set-of-16-821-16-/262795933374?hash=item3d2fdbb6be:g:9I4AAOSwt5hYcBJ-&vxp=mtr
At times you can find them for $75.
Its also not hard to modify a lifter like the 821-16 for better oiling like in a few odd classes that wont allow a edm lifter.
