I learned the hard way about 20 years ago, sprayed oven cleaner on a 71 Cuda grille to remove the argent. I left it to soak for a while and came back to find that It had melted the grille in multiple areas, it was a disaster.
Actual example for you right there! Like everything else, probably no where near as strong as it was back then. I remember when aircraft paint stripper felt like it was melting your skin off, now it barely even burns.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
