things that work..4 ways, brake lights, head lights and left turn signal flashes.
this tells you that from the connector behind the drivers kick panel that it is good downstream from there & also downstream forward past the firewall to the front lights including grounds cuz 4 ways & brake lights use the same large filament(s) in the 1157 bulbs. The TS flasher works both sides so it is OK. seperate the dangling ts/brake harness under the st column & ohm the col half for a start. try the stalk up/down & check continuities. this'll tell us if that assy is the problem.
