I'm buying a set for a low $$$ mostly stock carbed 5.9 Magnum with a Hughes Whiplash cam. I ordered an "old" Whiplash grind that doesn't require machining the heads for bigger springs.
Hughes claims that the Engine Quest valve guides will cause problems unless you buy a set from Hughes with their replacement bronze guides.
Has anyone had issues with these heads out-of-the-box? shruggy
