Originally Posted By MR_P_BODY
Bill.. at least you got your license passes
in and made a couple of runs.. and it came
home in 1 piece up
EDIT
My connector use to come loose and I had to
squeeze my connector(outside of the case..
easy fix)
wave
mike I think it's the pass thru connector, you can sit there and just spin the center part around and the wire is still tight, so I made up my own with a brass fitting, wire and some JB weld, then I will solder my crimp terminals when the JB sets up. up
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
