Originally Posted By The Shadow
This is all I can think reading this thread
Well if you would take any value from my work it is that if you have a Koleno block you should check all the oil holes for high spots before you have trouble.I think that is important or should be to someone with that block.
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
