Originally Posted By 440charger500
Originally Posted By fast68plymouth
They're going to bleed off after shut down....... So a little clatter after start up may be a fairly common occurance for you.
Took the car to the strip last night & ran some passes went 12.50's @ 109. I noticed in between passes letting it cool down cuz it was HOT 95 out, upon start up lifters clattered then calmed down after 15 seconds. Wondering if i should look into some different roller lifters as preventative maintenance Hmm
You couldn't GIVE me a set of Comp. Hydraulic roller lifters!
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
10.01 @ 133mph with a 250 shot of nitrous an a splash of race gas. 1.36 60 ft. 3,700 lbs.
