Stock drum, nonlow band apply trans break, bolt in sprag, was 8th pass on new trans that I had pro built. 4000 rpm launch, was having trouble with the launch. It would hook, spin, and hook again, which was shocking the sprag causing it to roll. Next is what you saw in the picture.
